09-13-2009 04:25 AM
I use diadem for view some data channels,and I have a time channel!BUt it's data depends on clock of the system that use it
for exampel if I use GMT time I have true data but If i use cairo(GMT+2), I have error in my time data in view.I have problem with this because I want to send my data to another system in an other city and I want to have the true data there too(with diffrent time zone).
09-14-2009 12:29 AM
Hi sahand2,
You didn't mention what type of data file you were creating. If DIAdem is creating the data file, I'm going to guess it's a TDM file. TDM files do not store the time zone by default as part of the date/time channel values. This is by design. You could argue that this is wrong, and you can certainly argue that this is different from LabVIEW's handling of date/time information, but it is intentional nonetheless. The idea is that most people don't want to use UTC time, and it would only confuse them.
So I'm afraid if you want to store UTC date/time information, you should add a property to the TDM file that contains your time shift from GMT, then apply that time shift to all date/time values after loading the data from the TDM file-- this will not happen automatically, but at least you will have a defined way of handling this feature gap.
Brad Turpin
DIAdem Product Support Engineer
10-01-2009 12:57 AM
10-01-2009 02:47 PM
Hello Sahand2,
Can you please let us know what versions of Measurement Studio and DIAdem you are using?
Otmar
