DIAdem
Power Point Report Default
Can anyone tell me how I can change the default Power Point Template to point to a template from my company, not the National Instruments Template.
Message 1 of 9
(6,586 Views)
I think it will depend on how you are opening powerpoint.  Can you give a little more information? For example, how are you opening power point, are you taking about doing this programmatically, or just changing the default in power point itself, and are you using power point 2007, or an older version?
Jensen
Message 2 of 9
(6,574 Views)
Hey Blane63580,
The default PowerPoint template is located in the DIAdem installation directory, installed by default to the following location:
"C:\Program Files\National Instruments\DIAdem 2010\Resource\PowerPointTemplate.ppt"
I recommend you rename that file but keep it as a backup, and then add your file with template in its place (and renaming it to PowerPointTemplate.ppt).
Derrick S.
Product Manager
NI DIAdem
Message 3 of 9
(6,571 Views)
Hi DRock,
is there another way to change the path. I don't have permission to Program Files.
Radek
Message 4 of 9
(6,243 Views)
Hi Radek Codr,
There isn't a way to change the file path, but you can run the following example script that ships with DIAdem to create PPT reports:
<DIAdem>\Examples\Documents\REPORT_Layout_to_PowerPoint.VBS
In that script, you can change the path used for the template.
Hope that helps.
Rohama K.
Message 5 of 9
(6,217 Views)
Hi Rohama_K
where or how can I change the path used for the template in this script?
Thanks for your answer!
Greetz,
cHristoph_TUD
Message 6 of 9
(5,962 Views)
Hi cHristoph_TUD,
You will need to change the following line:
sgSourceFile   = sPathDocuments & "" & "REPORT_Layout_to_PowerPointTemplate.ppt"
It should be the 55th line in the script. The way it works currently is it builds the path relative to the script location.
Rohama K.
Message 7 of 9
(5,924 Views)
would anyone provide the file
please. Unfortunately the example files are not installed on my computer.
Thanks.
Message 8 of 9
(4,357 Views)
Hi olhass,
Here are those 2 files from the DIAdem 2015 folder.
Brad Turpin
DIAdem Product Support Engineer
Message 9 of 9
(4,336 Views)
