08-12-2008 08:58 AM - edited 08-12-2008 09:00 AM
Solved! Go to Solution.
08-13-2008 09:55 AM
Hi Saurav Mukherjee,
The debugger that you have to download is the Microsoft VBScript debugger, not the Microsoft Visual C++ debugger. The VBScript debugger is a very small installation that you can get from Microsoft for free. Microsoft does not allow other products (i.e. DIAdem) to install their VBScript debugger.
Brad Turpin
DIAdem Product Support Engineer
08-13-2008 11:57 AM
Hello Saurav,
The debugger can be found here (well, at least until Microsoft decides to change the link again):
http://www.microsoft.com/downloads/details.aspx?FamilyID=2f465be0-94fd-4569-b3c4-dffdf19ccd99&DisplayLang=en#AdditionalInfo
The version of the debugger is 6,0,0,8424 if you check in the "DIAdem Help - About - Script Engine" menu.
08-14-2008 08:43 AM
Dear Otmar & Brad,
Thanks for your help. However I'm not able to find this script debugger in MS website. :mansad: Could you attach the same in your reply?
Thanks in advance,
With warm regards,
Saurav
08-14-2008 09:21 AM
Hi Saurav,
I'm curious, are you unable to connect to the URL that Otmar posted, or are you unable to use that Microsoft web site to download the VBScript debugger? I rather doubt that I'm authorized to post an installer from Microsoft in this forum that they have specifically protected behind an authentic Windows check at their web site.
Brad Turpin
08-14-2008 09:49 AM
Hi Brad,
I went to the url. After the few authencity checks, MS redirects me to a page saying that the particular download is not available!
WIth warm regards,
Saurav
08-14-2008 09:56 AM
Hello Saurav!
The link should work. Wich OS are you using?
Matthias
Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
08-15-2008 03:55 AM
I'm using WinXP Professional version. The authenticity check is successfully done. After it a page opens with the information that the download I'm looking for is unfortunately not available!!
MfG,
Saurav
08-15-2008 04:01 AM
Hello Saurav!
You have the same OS. This is not the reason for the problem. Can you try to download on another machine?
Matthias
08-15-2008 07:35 AM - edited 08-15-2008 07:35 AM
Saurav,
Please send me an email to: myfirstname DOT mylastname AT ni DOT com (no middle initials) and I'll send you an alternative way to get to this download.
