DIAdem
How to import a complex waveform in Diadem
I have a TDMS file storing a complex double waveform. I/Q data obtained from a USRP.
Is it possible to read these files in Diadem ? Complex data seems to be main issue.
Thanks for the help,
Laurent
(4,206 Views)
You are right. Actually is not able to load complex channels from TDMS files.
(4,183 Views)
Starting from DIAdem 2017 there is a pipe that transports the data as double channel if requested so. This enables work with the data even if not natively supported. A script is needed to access the complex channels.
"<tunnelcomplex>yes</tunnelcomplex>"
must be given as additional parameter.
Option Explicit
dim filepath : filepath = "C:\testData\tdms\Complexs.tdms"
dim plgParam : plgParam = "<filename readonly=""yes"">" & replace(filepath, "&", "&amp;") & "</filename>" &_
data.root.clear
DataFileLoad(plgParam)
dim rCh : set rCh = data.Root.ChannelGroups(1).Channels("C1")
dim iCh : set iCh = SplitComplexChannel(rCh)
function SplitComplexChannel(byRef mixCh)
  set SplitComplexChannel = nothing
  dim imgCh : set imgCh = mixCh.ChannelGroup.Channels.AddChannel(mixCh)
  imgCh.name = mixCh.name & "_i"
  mixCh.name = mixCh.name & "_r"
  Data.Move imgCh,  mixCh.ChannelGroup.Channels, mixCh.Properties("groupindex").Value + 1
  dim maxindex : maxindex = CLng(mixCh.Size / 2) - 1
  dim i : for i = 0 to maxindex
    mixCh(i * 2 + 1 + 1) = NOVALUE
    imgCh(i * 2 + 1) = NOVALUE
  Next
  Call ChnNovHandle(mixCh.GetReference(eRefTypeIndexIndex),"","Delete","X",1,1,0)
  Call ChnNovHandle(imgCh.GetReference(eRefTypeIndexIndex),"","Delete","X",1,1,0)
  set SplitComplexChannel = imgCh
end function
I added a script method to split a channel.
SplitComplexChannel
(3,144 Views)
How one can obtain Diadem 2017? The download page only has Diadem 2015.
(3,127 Views)
Hello Fedor,
DIAdem 2017 is currently announced for sometime around June of 2017.
You can sign up for the beta test program and get access to a pre-release version for testing here:
http://www.ni.com/beta
Otmar D. Foehner
(3,122 Views)
