Hi Rick
Just a few questions to clarify the situation:
1. Are you playing the video from a network location?
2. How large is the video file and what is the bit-rate?
3. Do you see the pausing and hopping when playing the video in Windows Media Player (WMP)?
4. Do you see the horizontal lines on the screen when playing the video in WMP?
The pausing and hopping may be due to the performance of computer, the size/bit-rate of the video, or a combination of all three of these factors. I'm guessing the reason you see a performance increase (no pausing or hopping) when you use the MPEG4 container is because the size and/or bit-rate of the video have decreased.
The reason you cannot seek to frames after converting to MPEG4 most likely due to the keyframes in your video file. Most mainstream video codecs use a difference algorithm to compute subsequent frames from previous frames. A keyframe represents a known, fully rendered frame that other subsequent frames can be computed from. As the frequency of keyframes decreases, the amount of time to calculate a given frame in the future increases (since the playback algorithm must compute each frame in between the current frame and the desired frame).
As you may already know, there are several third party programs that can update keyframes in video files, such as
VirtualDub. Enthusiast websites also exist, such as
www.doom9.org, with many detailed tutorials on using products like VirtualDub. Most pertinent to this discussion is the doom9 article under
Guides >> VirtualDub procedures >> Rederive keyframes.
If you are seeing the horizontal lines in WMP, then it is likely there has been in error in encoding the original video file and you may need to adjust the settings in your encoder utility.
