03-04-2009 11:14 AM
Solved! Go to Solution.
03-05-2009 12:40 AM
You can request the decimalpoint/delimiter you need if you start the CSV export from a script
Call DataFileSave( "<filename>C:\temp\EXAMPLE.csv</filename><decimalpoint>,</decimalpoint><delimiter>;</delimiter>", "CSV" )
see also http://forums.ni.com/ni/board/message?board.id=60&message.id=8851&query.id=146775#M8851
03-05-2009 08:26 AM
03-05-2009 08:41 AM
Thanks for the responses.
From document ID 3L9AKB4Y: "In Germany and the US, the comma has different meanings. Therefore, to avoid confusion by users from one country or another, CSV files are delimited by tabs."
Ironically this creates another confusion with the unconventional use of the file description "CSV" -- the user expects commas and gets tabs. ![]()
As an improvement suggestion why not have Diadem drop the "CSV" misnomer and call these files TXT or tab delimited similar to other software conventions?
03-05-2009 02:02 PM
Hello carowip,
You have an interesting point there, and I have forwarded this thread to the group manager in R&D to have a look at and come up with an idea.
Thank you for making me aware of this,
04-04-2011 07:55 AM
I am a Diadem-beginner. Can you tell me where to put this command, to get each file saved automatically?
Best regards
Wolfgang
04-05-2011 08:00 AM
Hi Wolfgang,
There is no way in DIAdem 2010 or earlier to have this change automatically applied. When you select the "File>>Save As" menu in the NAVIGATOR, you will always get the default "CSV" behavior of tab-delimited files.
What is listed above is the one command line you need to execute in a VBScript, which starts with "DataFileSave()", in order to programmatically save the CSV file with commas (or semicolons, or anything else) used as the delimiter character. Note that this particular feature is broken in DIAdem 2010 and fixed in DIAdem 2010 SP1.
Brad Turpin
DIAdem Product Support Engineer
05-02-2017 12:54 PM
The script shown as written exports a file with a comma decimal separator and a semicolon delimiter.
05-03-2017 11:11 AM
Hi All,
DIAdem 2017 has a new ASCII Export feature where you can choose the separator and decimal characters, the datetime format and the ASCII encoding, all in a pop-up dialog, when exporting the Data Portal to "CSV" or other ASCII format.
Brad Turpin
