07-25-2013 02:42 PM
Please post comments, feedback and questions for the Reference Design for Emulating an LVDT Using LabVIEW FPGA in this thread.
11-30-2015 08:44 PM - edited 11-30-2015 08:45 PM
Hi Christian,
I am trying to use the LVDT simulator in FPGA example that you have. I believe the VI's were written in Labview 2015. Can you save it in (convert to) Labview 2012 for me. My setup includes a PXe-8135 RT chassis with a NI 9144 expansion chassis over ETHERCAT.I have been speaking to Rachel Moore at NI & my specific support request number is 7469125.
The zip file on your forum is lvdt_simulation.zip. My email is: Harish.Lakshman@Honeywell.com
Harish
Phone: 310 512 1190
Cell: 310 245 5830
FAX: 310 512 2992
12-01-2015 06:08 AM
Hi Harish,
When I designed the code (2 years ago), I put the code in 2013 version. I think the migration process to latest version of LV is automatic (I haven't done anything). That being said, it doesn't answer your question, I know. I'm going to send you a message from my NI email address and see how I can help you.
Regards
Vincent
12-20-2015 06:00 PM
Hi Vincent.
I'm still on LV 2014.
Would you please help me with a previous version of your design: rainer.langlitz@k-dm.de
Rainer Langlitz
01-04-2016 07:40 AM
Hi Rainer,
Which method are-you interested in, the Simple or Advanced?
What is you use-case? What hardware do you use, what is the frequency of the excitation and accuracy requested?
Regards
Vincent
01-09-2016 05:34 PM
Hi Vincent.
I am interestd in the advanced method. My use case is a LVDT simulation with excitation frequency 3 kHz. The other requirements are not clear right now. I would like to run the simulation on a sbRIO. For the design verification I would like to run our code on a lab system to find out what minimum phase shift and accuracy I can reach with a sbRIO.
Regards
Rainer
04-18-2020 11:12 PM
Hi, I am trying to use the project for emulating an LVDT using labview FPGA, I am interested in the simple method, but I need help related to how modify diagrams to have a LVDT with central tap for the secondary windings, the excitation signal I need is a sinusoidal voltage of 7V RMS and 3KHz, a stroke range of 0.420 in
Thanks for your help
Cesar
04-23-2020 10:17 AM
Hi Cesar,
Have-you looked at the part running on Windows/RT side to compute the scaling factor (used on FPGA)?
At what rate do you need to update the simulated displacement?
What accuracy do you need on simulated displacement?
Regards
