05-03-2014 10:09 AM
Hi, in addition to the input terminal of multisim so I made file IO2 LabView LabView will work as well as control increases in value when the control voltage value is on the rise. But I want to increase of the resistor value , but I could not do it if you could help. In addition studies have LabView and multisim.
Best wishes
05-04-2014 02:01 PM
Yardım edecek kimse Yok galiba 😞
05-05-2014 01:32 PM
Hi there,
You will not be able to change the value of the resistor from LabVIEW using LabVIEW Multisim Co-simulation. With this approach, the input/output terminals can only be configured for voltage or current, not for component values.
If you need to automate the simulation (for instance: change component values programatically) you could use the NI LabVIEW Multisim API Toolkit, more info at:
Automate Student Assessment Using the NI LabVIEW Multisim API Toolkit
Best,
