Multisim and Ultiboard
how to construct current controlled current source
I wish to check my solution by using multisim,however, i don't know how to construct a circuit that contain current controlled current source. Hope anyone can help me.Thanks in advance
(22,963 Views)
If you look under Master Database - Sources - Controlled Current Sources, Select the component Current_Controlled_Current_ Source and wire it up.  Unfortunetly I don't know how to seperate the source and the measured current to make it look like your schematic but it should still work.
(22,938 Views)
Thank for your reply...I have tried to construct the circuit already.But the current that i get from calcuation is 254.8mA, and from the multisim, i get 181.819mA,i dont know which part i connect wrongly.Here is the circuit that i done.
(22,912 Views)
Accepted by topic author Evil-wing
The current sense should be placed between the the +12V and the 24 ohm resistor.
I just made the circuit and if you make the change, you will see that you are correct in your calculation.
(22,903 Views)
(22,893 Views)
You got it.
(22,883 Views)
thank you very much,you help me alot~~^^
(22,869 Views)
