Automotive and Embedded Networks
How to enable CAPL node in CANoe 7.5 ?
I am using CANoe 7.5 tool.
Using my existing configuration, In the simulation setup view did right click to insert CAPL node  , but the option is not available , I could see only replay block , generator block , Interactive generator block , others disabled.
Should I need to install any add-ons or use specific configurations ?
If anyone had gone through this , please advice.
Thank you !
(9,586 Views)
Hi K1504,
What is your hardware/software setup?  Could you outline what National Instruments hardware or software you are using?
I will then be able to help with the issue.
Regards
Matt Surridge
(9,559 Views)
