01-27-2015 11:19 PM
Hi All
For some testing purpose (see this post for the background), I removed the wireless driver that came along with myRIO 1900. After that, while doing a software update, the connection broke in between. Ever since I have not been able to communicate with myRIO. I can see myRIO occasionally in MAX, and also in the PC as a USB device, but cannot even do a software restart. The startup wizard fails to recognize any device being connected to it. I am able to connect to myRIO using SSH. Attached is a screenshot of what I see after giving 'dmesg'.
Also, LV is able to detect myRIO from the project, but it hangs when I try to deploy code. I tried formatting it when it gets identified in MAX (which is rare). But a communication failure error pops up.
Is there any way by which I can reconnect/do a reset of the device?
Arya
03-04-2015 07:14 AM
Hi All
Finally, I was able to establish some connection with the device, flash the latest firmware, format the disk and bring it back to normal. The main trouble was that if the WiFi is removed, MAX was hanging continuously, which prevented me from accessing myRIO practically all the time.
Arya
