Digital Multimeters (DMMs) and Precision DC Sources
DAQmxGetSysDevNames not recognize NI PCI-4065
I'm developing an application using the DAQmx C API and I have many NI Board on pc.  I know how to read more detailed device information using DAQmxGetSysDevNames(), DAQmxGetDevProductType(), DAQmxGetDevProductCategory() and so on.... All work fine, the only problem is NI PCI-4065 that DAQmxGetSysDevNames() not recognize in the return string. The device is ok, because MAX tell me that it is "Dev2" and so i wish that DAQmxGetSysDevNames() returns also "Dev2" with other "Dev1 Dev3 Dev4 ...."
Someone has some suggestion?
Thanks and sorry for my bad english
Alessandro
(6,847 Views)
Ciao Alessandro,
I've found a pretty similar issue at this link.
Take a look also at this document:
Using NI-ModInst to Query Device Specific Information
Hope this can help.
Ciao,
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(6,822 Views)
