08-12-2005 12:03 PM
08-15-2005 01:25 AM
08-15-2005 12:54 PM - edited 08-15-2005 12:54 PM
Message Edited by Tom W. on 08-15-2005 12:54 PM
08-15-2005 04:10 PM
08-13-2006 03:49 AM
This function (DAQmxSetDOOutputDriveType) does not appear to be available under Linux with NIDAQmxBase 1.5, which appears to be the only thing that works under Linux for the 6501. What are my options?
I'm trying to check continuity through a device (before testing starts) by sending High, then Low, then High from one of the outputs on the 6501, and reading the results on an input on the 6501. I see that I only get a vary brief High on the output, then it falls to low, until I disconnect the output from the input pin.
Any thoughts?
08-14-2006 03:46 PM
08-14-2006 10:04 PM
Unfortunately, this is part of a piece of test equipment, which is required to have no user intervention - just turn on, boot, and run - no GUI desktop or anything (just log in as root and run the program). Is there no way to do this through C or a command line interface instead of having to use the GUI config utility?
Thanks.
08-15-2006 01:54 PM
11-18-2008 09:25 AM
Try to wire it other way around: http://forums.ni.com/ni/board/message?board.id=70&message.id=9871#M9871
