DIAdem
diadem script
Hi all,
is it possible to access the number of channels of a lvm file from Diadem Script without loading the whole file into the data portal?
David
(3,754 Views)
Hi David,
If you have DIAdem 10.1, then you can use the new DataFileHeader object to interrogate a data file without having to load it:
DataFilePath = ProgramDrv & "Demo\Dat\Example.LVM"
Set DataFileHeader = DataFileHeaderAccess(DataFilePath, "LVM", TRUE)
MsgBox DataFileHeader.GroupChnCount(1)
Alternatively, if you have DIAdem 10.0 and the LVM file happens to be in a search area, you could programmatically query the file and return the Group level and count the number of return rows in the Search Results Table.
Ask if you need more information,
Brad Turpin
DIAdem Product Support Engineer
(3,722 Views)
Hi Brad,
thanks for your response.
unfortunately, I don't have Diadem 10.1, but 10.0 installed. Therefore I can't use the DataFileHeaderAccess function. The way to work around it I found is:
'get number of channels in file
Call DATAFILELOAD(filename,"","Register")
chns = GroupChnCount(GroupIndexGet("LabVIEW_Data"))
Call DATADELALL
Not loading but registering the data works a lot faster!
David
(3,703 Views)
