Working on a driver for a custom test equipment solution. This error consistently pops up. If you look at the stack trace, it appears like it happens when nipalk interrupts my dispatch routine. I'm looking into if I am causing this somehow. It would be nice if someone could tell me whether the ni driver is actually trying to access paged memory from the interrupt or if this bugcheck is because the memory pointer is actually corrupted. I can provide the kernel memory dump. Let me know how best to proceed. Thanks.
Don Walker
Honeywell
913-712-2193
don.walker@honeywell.com
*** Fatal System Error: 0x000000d1
(0xE13C71C8,0x0000001C,0x00000000,0xF2D71F69)
Break instruction exception - code 80000003 (first chance)
A fatal system error has occurred.
Debugger entered on first try; Bugcheck callbacks have not been invoked.
Connected to Windows 2000 2195 x86 compatible target, ptr64 FALSE
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {e13c71c8, 1c, 0, f2d71f69}
*** ERROR: Symbol file could not be found. Defaulted to export symbols for nimdsk.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for Nidaq32k.SYS -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for nipalk.sys -
Probably caused by : nimdsk.dll ( nimdsk!NIMDS100::tMDSPrimitive::_markAllAttributesChanged+2a9 )
Followup: MachineOwner
nt!RtlpBreakWithStatusInstruction:
80455554 cc int 3
kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: e13c71c8, memory referenced
Arg2: 0000001c, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: f2d71f69, address which referenced memory
Debugging Details:
READ_ADDRESS: e13c71c8 Paged pool
CURRENT_IRQL: 1c
FAULTING_IP:
f2d71f69 393c98 cmp dword ptr [eax+ebx*4],edi
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: Debugger.exe
TRAP_FRAME: eb423d7c -- (.trap ffffffffeb423d7c)
ErrCode = 00000000
eax=e13c71c8 ebx=00000000 ecx=0000002f edx=00000000 esi=f16e6cb0 edi=00000115
eip=f2d71f69 esp=eb423df0 ebp=eb423e48 iopl=0 nv up ei pl nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010202
nimdsk!NIMDS100::tMDSPrimitive::_markAllAttributesChanged+0x2a9:
f2d71f69 393c98 cmp dword ptr [eax+ebx*4],edi ds:0023:e13c71c8=000000d2
Resetting default scope
LAST_CONTROL_TRANSFER: from 8042a9e7 to 80455554
STACK_TEXT:
eb4239a4 8042a9e7 00000003 eb4239ec e13c71c8 nt!RtlpBreakWithStatusInstruction
eb4239d4 8042afda 00000003 e13c71c8 f2d71f69 nt!KiBugCheckDebugBreak+0x31
eb423d60 80467df7 00000000 e13c71c8 0000001c nt!KeBugCheckEx+0x390
eb423d60 f2d71f69 00000000 e13c71c8 0000001c nt!KiTrap0E+0x20b
WARNING: Stack unwind information not available. Following frames may be wrong.
eb423e48 f244d7c0 00000000 f88c3550 f88c4c00 nimdsk!NIMDS100::tMDSPrimitive::_markAllAttributesChanged+0x2a9
eb423e70 bfec9627 80030000 bfeea7e4 f88c34d8 Nidaq32k!mdsSCXICommDigPrimitive::shiftOneByte+0x3cc00
eb423e8c bfeeb18e 8179b008 f88c34d8 8209a00c nipalk!tBusFlavorSimulated::tBusFlavorSimulated+0xc7
eb423ea4 bfeeb3f9 8209a00c bff0c067 8179b008 nipalk!tInterruptGroup::_serviceHardwareInterrupt+0xce
eb423ec0 bfeeab57 eb423edc f88c07c0 eb423ee8 nipalk!tInterruptGroup::_setLockState+0xb9
eb423ed0 bff0bf6c eb423edc bff25760 00000000 nipalk!tInterruptGroup::runAtomicOperation+0x47
eb423ee8 80468a80 8179b008 f88c34d8 00000012 nipalk!tTimerTimeWasterSleep::sleep+0x304c
eb423f00 80468a48 02000002 00000039 8041e152 nt!KiChainedDispatch2ndLvl+0x28
eb423f00 8042b715 02000002 00000039 8041e152 nt!KiChainedDispatch+0x28
eb423f90 804354ba 81fce164 00000000 00000000 nt!KeSetEvent+0x33
eb423fa0 f8821c92 81fce164 00000000 00000000 nt!VerifierSetEvent+0x34
eb423fb4 f882e78e 81fce140 81fce0d0 00000001 RT429SIM!WriteQueueHasData+0x22 [d:\winddk\3790.1830\src\rt429sim\filethread.c @ 311]
eb423fc8 f882168d 81fd7068 00000000 81fce0d0 RT429SIM!MaintainADLPTimersFiles+0x8e [d:\winddk\3790.1830\src\rt429sim\adlp_718.c @ 1953]
eb423fe0 804644c7 81fce08c 81fce018 00000000 RT429SIM!DpcForIsr+0xad [d:\winddk\3790.1830\src\rt429sim\isrfunc.c @ 283]
eb423ff4 80468eaa f2bb0ce0 00000000 00000000 nt!KiRetireDpcList+0x30
eb423ff8 f2bb0ce0 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2a
80468eaa 00000000 00000008 bb835275 00000128 0xf2bb0ce0
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: nimdsk!NIMDS100::tMDSPrimitive::_markAllAttributesChanged+2a9
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nimdsk
IMAGE_NAME: nimdsk.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 3ce40f83
FAILURE_BUCKET_ID: 0xD1_VRF_nimdsk!NIMDS100::tMDSPrimitive::_markAllAttributesChanged+2a9
