Multisim and Ultiboard
lm2907 not enough notes found
I'm trying to import this spice model into multisim, but it keeps saying, "not enough nodes found"
http://www.geocities.com/russlk/LM2907.txt
any tips would be good
(8,502 Views)
fixed.
(8,494 Views)
Do not know how you imported this, but if you imported the whole file then that may be what the problem is. The only thing from this file that Multisim needs is the portion from the .SUBCKT line to the first .ENDS statement. The other portions of this file contain external circuitry and spice commands for the particular simulator that this file would be 100% compatible with as is.
Try this and see if it works for you.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(8,492 Views)
thank you i just realised that was an issue and fixed it... now im trying to find models for any DC-DC converters to work in multisim
(8,490 Views)
Yea, you had already figured it out while I was typing my response. That was cool. I am not sure which Version of MS you have. I have the Power Pro Version and there are a few generic DC-DC Converters in the database. These are listed under POWER>BASSO_SMPS_CORE. You can take a look at these if you have them. I do not know if they would be suitable for you application or not, but I thought I would let you know about them.
Have a Nice Day
(8,483 Views)
Thank you greatly for your help it helps quiet a bit.
(8,471 Views)
