how to append the dynamically created sequence in to the main sequence
i have created a sequence dynamically using c# with myEngine.NewSequence(). I  am loading this sequence into a sequence file created using myEngine.NewSequenceFile(). every sequence file has a main sequence by default. Now I need to append the created sequence in to the main sequence. can you please help me to solve this issue?
(3,373 Views)
1. Sequence seqMain = seqFile.GetSequenceByName("MainSequence");
2. Your stuff that creates a SequenceStuff e.g. "Hello"
3. Step stepSeqCall = engine.NewStep(AdapterKeyNames.SequenceAdapterKeyName, "SequenceCall");
4.stepSeqCall.Name = "HELLO" or sequenceStuff.Name;
5. objModule.UseCurrentFile = true;
6.objModule.SequenceName = stepSeqCall.Name ;
7.seqMain.InsertStep(stepSeqCall, nSeq, StepGroups.StepGroup_Main);
Greetings from Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,352 Views)
I have tried this already. But it is again 2 main sequences in the sequence file as shown in the attached screenshots.Is there any possibility to avoid that?
(3,349 Views)
Hi
Calling engine.NewSequenceFile();
creates a file where a empty MainSequnence is persent. So you not need to create it once more.
To get the SeqenceObject for inserting your steps in MainSequence. Use
GetSequenceByName("MainSequence") for doing this.
Juergen
--Signature--
(3,344 Views)
