I am having a problem where teststand is interpretting my strings, when all I want is for it to pass the string to my api exactly as it has been entered.
I have a TestStand step that calls a method on my COM object, passing a string parameter. I have entered the parameter into the sequence as
"\\QESP42200M2\Process\Providers\VRSample\Servlets (By Type)\Setpoints\TestScaleFactor"
but when I run the sequence, by method receives the following string.
"\QESP42200M2\Process\Providers\VRSample\Servlets (By Type)\Setpoints|estScaleFactor"
So it's interpretting the '\\' as '\' and '\T' as a tab.
I understand that the string will come out correctly if I double up my back slashes, but this is highly inconvenient for me. E
very other component in my system passes strings as data (ie. no interpretting of what's in the string), and I would have to make special rules for TestStand.
Is there any way I can make TestStand stop doing this?
Aaron Stibich
Senior Engineer
Innovative Technologies Inc.
925-803-2884
