type conflict error when using TS_EngineGetSeqFile
I was trying to use function TS_EngineGetSeqFile to load a sequence file build in TestStand 4.0, and I got a OLE error showing me that I have a type conflict with "CommonResults". Does anyone know how to solve this problem??
(4,571 Views)
Hi huizhong,
The type conflict dialog you are seeing is evidence that the copy of CommonResults (an NI-Installed type) in the sequence file has the same version but different settings than the currently loaded CommonResults type definition. CommonResults is stored in almost all of the built in TestStand type palettes which automatically get loaded when you open TestStand. Because of this, it becomes a part of the global type usage list in the Engine. If you didn't make any changes to CommonResults yourself, it is likely you have inherited a type virus from somewhere and I suggest you take measures to correct the problem.
A type virus can spread when you tell TestStand to resolve a type conflict by using the version from the file you are currently opening (as opposed to the currently loaded type in the global type usage list). Once the "new" type is copied over to the type palettes, it will then get loaded every time TestStand runs. At this point, if you open up more files that use this same type and choose to use the currently loaded type when the type conflict dialog shows, TestStand will copy the "new" version into the file - thus the spread or viral like behavior.
In order to correct the problem, you can either:
  • Manually open each and every infected file and replace the invalid type with the valid type or...
  • Use the Type Differ tool that I wrote to inspect each file pair and merge the conflict automatically
I realize that using the Type Differ at this point is still "manual" in the sense that you must open each file pair and merge the conflict, but hopefully in your case there aren't that many affected files. To that end, I am working on a Batch version of the Type Differ that can diff and merge entire directory structures automatically. Let me know if you are interested in using such a tool and I will post a link when development has reached a beta version.
(4,549 Views)
Hi James,
Thank you for your detailed information about the conflicts. This is the first time in this forum that somelse speaks out my words. - A type virus.!! Everytime I told my colleages (and myself too) to be extremly carefully with conflict messages  because a wrong click in the dialogbox can produce a behavior like a virus.
I am so glad that you worte "Type differ". At moment I had no use for it, because i can hold the virus in stall. But i know there is the time when someone is doing a wrong click and then the Teststand-machines in the production field begin to popup a conflict.
Hm! Now think I have to write a "virus" to check your tool Smiley Wink
Greetings from the lake of constance, Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,539 Views)
Hi Juergen,
I'm glad I could be of assistance. I induced many viruses on my own computer during development. If you find a case that it misses, please let me know!
(4,512 Views)
