02-15-2007 12:57 PM
02-16-2007 04:47 PM
02-16-2007 05:27 PM
02-19-2007 09:22 AM - edited 02-19-2007 09:22 AM
Message Edited by kirsch on 02-19-2007 09:24 AM
02-19-2007 10:07 AM
Thank you - Marcos. You helped me second time.
>> All our AWGs have relays so they can achieve the desired gain by switching in and out a series of amplifiers and attenuators with the best possible analog performance.
I waited relay only in output of AWG channel.
Yes, C program changes gain. When generation stops AWG produces tha latest value. So I am not only stop generation I also play 0-value waveform with minimum points and set gain = 1 that is not equiled previous vaweform. (I think this is well done behavior.)
And last, time to time NI's hardware manuals haven't enough information.
02-26-2007 11:11 AM
Marcos hi
I thought a little ...
I suppose this card has just output relay. It is imposible that this type gain has relay. It can be if the card has set of gains. In this case when any gain can be setting it is implemented on DAC.
So ... when I change gain driver switch off output relay, changes gain and switch on relay again. Can you ask NI developers?
Thanks, Andrei.
02-26-2007 11:50 AM
02-26-2007 12:05 PM
Marcos hi,
Your answer really surprised me.
You wrote about the same approaach what I means, like DAC. I couldn't image this.
Thank you very much for your explanation.
I hope I will not have problem with system. When I will have chance (now system is used) I will set max gain in setup time and will tune waveform (less then -1 -> +1 V). Currently, I try to have max accuracity and I prepare waveform ( always == -1 -> +1 V) and tune gain.
Thank you again, Andrei.
