NI-CAN Initialization fails for NI-PCI 8512(XNET Interface)
Hi all,
I'm pretty new to XNET and I wanted to use my old NI-CAN drivers for the NI-PCI 8512.As the device is listed under FLEXNET interface,I'm not able to allocate CAN channel or to set the baud rate to use with NI-CAN. I'm getting following error message:
"Error -1074388957 occurred at CAN Initialize.vi
Possible reason(s):
NI-CAN:  (Hex 0xBFF62023) The Interface is invalid or unknown.  Solution:
Verify that the interface is assigned to a specific port within the Devices
and Interfaces branch of  the Measurement and Automation Explorer (MAX)."
Attaching a scrren shot of my MAX CAN Setup.
I would really appreciate if anyone encountered the same issue and was able to resolve it.
Manu Mohan
(9,945 Views)
I forgot to mention that the NI Bus monitor work perfectly to show me the incoming messages.
(9,943 Views)
Accepted by topic author manumohannair
To use NI CAN API, we need to install a “compatibility layer” software interface… Following link resolves the issue
http://zone.ni.com/devzone/cda/tut/p/id/9717
(9,929 Views)
