timestamps 2-port NI CAN Card
can anyone tell me weather the timestamps of the CAN messages received at 2 ports in a PXI-8461-2 port-Series2-high speed Card
be compared?
I have 2 applications, each using a separate CAN port connected to netwroks with different baudrates.
I am logging the frames to different files. Can i correlate the frames offline based on thier time stamps?
does the 2-port CAN Card share the same clock to add the timestamp to each CAN message at each port?
if not, are the 2 clocks synchronized so that the time stamps can be compared?
(6,288 Views)
Yes both ports use the same timebase and you should be able to compare both timestamps.
DirkW
(6,282 Views)
Hi Dirkw,
Thanks.
but i did not see any hardware manual that describes that the timebase is same for both the ports in PXI-8461.
could you pls share if you have one?
(6,280 Views)
Within the driver manual on page 10-33: The 20 MHz Timebase applies to the entire CAN or LIN hardware, including both interfaces of a 2-port CAN card.
DirkW
(6,270 Views)
