08-27-2007 03:20 PM
I am trying to increase the speed that my VI samples and writes at. I have come across different ways of accomplishing this task, but am not sure what change (or combinations of changes) will work most efficiently.
Here is a brief outline of my program:
- Uses LabVIEW 7.1, DAQmx 8.5 and NI USB 6211
- Reads in 8 Analog Inputs
- For one of the analog inputs, there is an analog output that depends on its voltage value
- I need my application to update at a rate of 100 samples / second (or faster)
- I would prefer the AI and AO to run in synch with eachother, or with a very small lag time (less than 0.01 s)
Possible solutions:
1) Make parallel loops - one for AI and one for AO (this worked for me when I was using a card from MCC, but I can't get both loops to execute continuously with this USB card)
2) Change the buffer size / how the buffer stores and releases data. I have read the note on how the buffer size is determined for a continuous acquisition, but for some reason, this value gives me the error 200279, meaning that I am not removing data from the buffer fast enough.
3) Get rid of the express VIs (I currently cannot seem to implement a case structure in place of the comparison express VI that does not execute sequentially)
I have attached my VI that makes use of the express VIs since it is the most clear depiction of my program. This discussion forum has proved to be very helpful for me in the past so If anyone has any examples or knowledge that pertain to my application, I would appreciate any help that I can get!
Jenna
08-28-2007 02:52 PM
Hi Jenna,
You might want to reattach your VI it didn't seem to get attached. It
sounds to me like your setting up some type of PID. Is this true?
What type of calculations are you doing with the analog input voltage value and
what are you outputting from the analog output?
Based on what you have described, I think you might try parallel loops (one for
analog output/input and one for calculations) and send the data from the analog
input with a queue to the calculation loop which will send the information back
to update the analog output (this will cause some "lag time" but then
your analog inputs will be read continuously at the proper rate). Click here for more information
on using queues.
In your second question, you ask about buffer sizes. The reason you’re
getting that error is likely due to the fact that you’re not reading the data
from your buffer fast enough. Since your only acquiring data at 100Hz,
you could probably increase the buffer size to delay this error; however, the
best solution would be to read more samples each time (set samples to read
larger). A good rule of thumb is to set your samples to read at approximately
10% of your sample rate. This is just a rule of thumb and can depend on
other factors like how often your DAQmx read is executing (how fast you’re
while loop is executing). For example, if you’re sampling at 1 KHz, you
would want to read 100 samples every DAQmx read, but if your DAQmx read only
executes only once every 3 seconds this might still cause buffer
problems.
In regards to your third question, could you explain a little more about what
type of comparisons are you doing?
In addition, I would take a look at the DAQmx synchronization examples (Help »
Find Examples » Hardware Input and Output » DAQmx » Synchronization »
Multi-Function » Multi-Function-Synch AI-AO.vi. This example doesn't use
feedback from an analog input but is good for showing how to setup two tasks
(one as the master and one as the slave) to start synchronized.
I hope this helps,
Paul C.
08-28-2007 03:20 PM
08-29-2007 03:12 PM - edited 08-29-2007 03:12 PM
Message Edited by Paul C. on 08-29-2007 03:13 PM
08-31-2007 10:40 AM
Hi Paul,
That will definitely be helpful when I expand the amount of comparison tasks that I perform with my VI, thanks!
Right now I am still getting the buffer error where the samples are being overwritten (Error 200279). This error appears periodically at the beginning of a data acquisition trial and I am not certain why this would be the case as opposed to having the error appear all the time.
The producer/consumer application design pattern is also a bit confusing to me. Can I read the info from the DAQ assistant into the queue in a producer loop and write, view and calculate data in the consumer continuously? Can I use occurences in addition to queues if I want to synchronize the two processes and eliminate the lag time?
I understand what the producer/consumer and master/slave design patterns are trying to accomplish, but it’s incorporating that into my VI that is giving me a headache!
Thanks for your help
Jenna08-31-2007 02:40 PM
Hi Jenna,
The buffer error (-200279) is most likely due to you not reading enough samples
from the buffer each iteration of the loop. It sounds like the loop you
use to do the DAQmx read is probably slow (due to other processes running such
as the comparison express vi's) and you aren't compensating for this slow
process time by increasing the samples to read. You might try using the
value of -1 for samples to read. This grabs all the available samples off
the buffer every iteration of the loop. In case you didn’t know, when you
get an error in LabVIEW, it is often helpful to use Help » Explain error.. to
help troubleshoot what types of things you can try to eliminate the error.
In regards to your questions about the producer/consumer application, "Can I read
view and calculate data in the consumer continuously?" Yes. The
point of the queue for your application is to separate your loop for analog
input data acquisition with the loop for calculations and analog output.
The first things I would look at are the templates that can be found in
LabVIEW. Go to File » New... » VI » From Templates » Frameworks » Design
Patterns and take a look at the different templates for these ideas. I
would also recommend taking a look at the Master/Slave Design Pattern. It
uses notifiers instead of queues which might work better for your application. The reason I recommend trying notifiers is
because they pass the most recent data where queue would just pass the next
data point in line. A queue takes in all
the data in a line so that when you dequeue the data it will just take the next
element in line. A notifier stores just
the most recent piece of data and throws out the old. So, when the “wait on notification” vi is
executed, it just grabs the most recent data instead of the next data in line. This will allow you to calculate your analog output value based on the most recent analog input values. This will essentially make the program adjust to possible lag time.
In terms of program flow, I would recommend the following. First, you will need to have the
"master" loop take in your analog inputs and either use notifiers or
queues to send the data (specifically from the one analog input your using as a
reference: take a look at the split signals vi) from the analog input loop to the “slave” loop. The “slave” loop will then be used to grab
the most recent data, or the next in line if using queues, from the analog input and use it calculate the analog
output. This allows you to keep the analog input loop running at a decent
rate without slowing it down by your "slave" loop which is doing analog output updates and calculations.
In
terms of lag time, there is always going to be some lag time between your
analog input and your analog output. It is going to be the sum of the
analog input measurement time, the calculation process time, and the time it
takes to output that data to an analog output. What we are trying to do
is find ways to reduce this "lag time" to as little time as possible
by making your code more efficient. By taking out express VI's like the
DAQ assistant, we can avoid having to create a new task every iteration of the
loop and initialize that task. By setting up the DAQmx task prior to the
loop, the only thing the DAQ driver is doing during each iteration of the loop
is executing the DAQmx read. Another example
is with the comparison express vi. If
you can do the specific comparison directly, you can eliminate some extra
processing time that is used by the comparison express vi.
I
hope this helps,
Paul
C.
09-04-2007 02:09 PM
09-05-2007 05:32 PM
09-06-2007 07:51 AM
I contacted NI support hoping to find some examples of queues (or notifiers) being used with AI and AO and they provided me with one. The design templates helped me understand the subVIs and how queues work... but I was still unsure of how to modify it for my application. I really do appreciate all the help I've gotten from this discussion board and have implemented Paul's suggestions into my programming.
I've attached my VI as it stands right now for anyone who is interested. I appologize if it is a little bit messy.
Data seems to be passing nicely into the consumer loop with the calculations (can see this with the Analog Out graph), but the AO doesn't seem to be updating while the VI is running (AO voltage wired to AI seen in the Gate voltage graph). This might be because of the way the VI is wired... but I'm not sure.
I can post the final VI when it is finished.
11-09-2007 04:12 AM
