06-05-2007 11:01 PM
06-06-2007 04:50 PM - edited 06-06-2007 04:50 PM
Hi Ace,
I noticed that you started an identical thread here. In the future, please try to limit your posts to a single thread so that all responses can be contained to a single conversation.
First, I recommend that you read the documentation that DevChander refered to here. This will be very useful as you get started with the DAQ Assistant.
As far as using the digital reading from your 6009 to control a separate VI, I have never done so, but I imagine that something like this would work:
Note that the signal from the first channel is used to control the state of the case structure. The second channel is used to written to the shared variable which would control the front panel object of the subVI.
Message Edited by Luke G on 06-06-2007 04:51 PM
06-12-2007 10:32 PM
06-12-2007 10:33 PM - edited 06-12-2007 10:33 PM
Message Edited by Ace666 on 06-12-2007 10:49 PM
06-13-2007 12:52 AM
06-13-2007 01:02 AM
06-14-2007 08:49 AM
06-19-2007 10:06 PM
06-21-2007 09:19 AM
Luke's example does exactly what you need - you jusst need to setup the digital input up to read the line you want to poll.
Regardless, here is an example that fires up a pop up VI at the press of a button: http://zone.ni.com/devzone/cda/epd/p/id/1146
You just need to replace the logic with a DAQ Assistant that reads the digital input continuously.
06-27-2007 12:18 AM
