05-31-2007 05:54 AM
05-31-2007
07:24 AM
- last edited on
06-28-2024
09:06 AM
by
Content Cleaner
Although the E series cards allow to use quadrature encoders, I'm afraid that their DAQ-STC counters don't support Z.
The default pins for the new generation of M series cards are listed here. Obviously, the default pins can be changed through DAQmx property nodes.
06-01-2007
11:19 AM
- last edited on
06-28-2024
09:06 AM
by
Content Cleaner
Hi Yasser,
All E series cards (PCI-60xx) do not support Z indexing.
You can use a separate counter on another board to measure the Z index. This line will pulse every time it makes one complete revolution. This line is intended to measure absolute position of the encoder.
The advantage of using a M series board (PCI-62xx) is it does support Z indexing.
