Measurement Studio for VB6
Complete setup of CWserial object in VB6
I'm looking for complete examples of a setup of the CW serial object for my VB6 app.  I need setting parameter, output, input, events if applicable, etc.
(6,814 Views)
There should be an example that installs when you install Measurement Studio for VB 6.0.  It is located at C:\Program Files\National Instruments\MeasurementStudio\VB\Samples\Instr\Basic Serial, assuming you installed Measurement Studio to the default directory.  If this example isn't there, you need to reinstall Measurement Studio and make sure to install the instrument components.
Pat P.
Software Engineer
(6,796 Views)
