05-26-2010 06:32 AM
Hi .Please download the images named "333-1.png" and "333.png" from the attachments first.I want to extract the image named "333-1.png" from the image named "333.png" automatically .But how can I do ? I hope that you can help me.Thanks.
melo_xu
Solved! Go to Solution.
05-26-2010 06:56 AM
Please stick to a single thread. Since this post contains the attachment we will continue here. Try applying threshold and extracting using particle filter.
05-26-2010 07:05 AM
This will work
05-26-2010 08:58 AM - edited 05-26-2010 09:00 AM
Thank you for your help ,Muks! I have solved this problem by your VI. I hope that I can learn more from you ! If I have any other questions ,I think I will still need your help.
melo_xu
05-26-2010 08:59 AM
melo_xu
05-26-2010 09:07 AM
11-30-2011 12:58 AM
HI Muks,
Are u doing extract.vi with vision assistant? I want to extract the car license plate number from the cars with vision assistant. I already modified and tried ur program. It's not work with my car photos. Can u show me the script that u use in this program?
