I have another problem that came with installing VBAI 3.0.1. It also updates the MAX to version 4.2. I cannot locate the CVS using the Create New... for Remote devices. When I enter the IP address, it says that the device on that IP is not supported.
And there is a second problem with MAX 4.2. When I close the application an error dialog box appears with some Pure virtual function call. I attach the screenshot.
In order to successfully detect the CVS through MAX and VBAI, you need to install the CVS support. The CVS support is installed with NI-IMAQ I/O which ships as part of Vision Acquisition Software.
