In LabWindows/CVI 8.1.0, in the "Find Results" window, can the file paths be suppressed so that only the found text is visible? If you have a long file path, the found text is always off the screen.
I think you're right about the Find Results needing a tweak. The file path and found text should really be in separate columns, so that you could size down the path column to bring the text into view. I encourage you to submit this as Product Feedback so that it is properly tracked and prioritized.
