Is it possible to have mutually exclusive dialog radio buttons?
Is it possible to create a set of mutually exclusive dialog radio buttons in such a way that only one radio button per set can be selected at a time? Can LabVIEW detect which buttons are pressed to ensure only one is set to true before the program runs?
Message 1 of 33
(12,997 Views)
I would create a couple events/or case, in which if one radio button is pressed, the rest are disabled (or even disabled and grayed). This way you will be able to ensure that only one button is pressed at the time!
USCTrojan
Message 2 of 33
(12,993 Views)
The proper way of doing this is, believe it or not, with a customized slide control. It looks like radio buttons and outputs the number of the option selected.
Attached is a VI showing two I put together. To use them use the text control at the bottom of the control to set the name of the buttons, or add new ones by adding items to the list.
Once you have the items configured, right click on one of the buttons and select Visible>>Text Display to hide the text display and you're read ro rock and roll.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 33
(12,992 Views)
This was way too cool...
www.vartortech.com
Message 4 of 33
(12,992 Views)
Great idea Mike!!!
Alberto
Message 5 of 33
(12,992 Views)
This is very good.
Message 6 of 33
(12,988 Views)
Only wish I could take credit for it, but it came about at least two or three major revs ago...
Mike...
LabVIEW Champion
Message 7 of 33
(12,988 Views)
Thanks Mike for the great way of doing things!
I wonder how did you customize the slide control to make it look that the VI that you've attached with your answer?
FightonSCTrojan
Message 8 of 33
(12,809 Views)
Yeah. I've always wondered why this radio button technique hasn't made its way to the standard control palette yet. IIRC the codeless radio button was first published by Stepan Riha in LTR long ago.
LabVIEW, C'est LabVIEW
Message 9 of 33
(12,988 Views)
Basically, when you go into edit mode you can copy and paste graphics to be used for different display components. I made the marker indexes look like unselected booleans, and the slider look like a selected boolean.
Mike...
LabVIEW Champion
Message 10 of 33
(12,809 Views)
