10-26-2009 01:08 PM
Darren wrote:Very cool tip...I was not aware of the Matrix Size function. Perhaps I will steal borrow this tip for a future Darren's Weekly Nugget. 😉
I just benchmarked the two approaches, and it looks like Matrix Size is slightly slower than the Array Size -> Index Array approach, but unless you're calculating 2D array sizes in a very tight loop, it shouldn't make enough of a difference to account for the usability and real estate advantages of Matrix Size.
-D
Edit: Whoa! I just discovered that it works for *any* 2D array...it doesn't even have to be Numeric! This may just be cool enough to be today's nugget. 🙂
Message Edited by Darren on 10-26-2009 01:04 PM
Please feel free to borrow/steal/pilfer as I am having a hard time stopping myself from having a VIOTD on the Implies function.
10-26-2009 01:17 PM
Implies! If this thing is true and this other thing is false, do something. Otherwise, do something else. A situation that comes up surprisingly often in LabVIEW. You should definitely write a Function of the Day post about it... 😉
10-26-2009 01:46 PM
Darren wrote:Implies! If this thing is true and this other thing is false, do something. Otherwise, do something else. A situation that comes up surprisingly often in LabVIEW. You should definitely write a Function of the Day post about it... 😉
Let me make sure I understand this implies thing:
If Title="VIOTD" is True and Misuse in Post is False, get off my case, otherwise, throttle me with my own mouse.
You are right, that does come up fairly often.
10-26-2009 02:27 PM
