How to set XControl default type to be a "control"?
Hi all,
LabVIEW 2009 + DSC
How I can set XControl default type be a "control"? E.g. when I drag and drop Xcontrol from project to VI it is always indicator type and I want it to be a control. Of course I can change it manually after dropping but when there are numerous XControls this takes time.
BR, Jim
(2,950 Views)
Accepted by SnowForest
In the facade VI you can get the 'Direction Change event' use the following code to be an 'indicator only'
The same code can be used in the init state.
Ton
Message Edited by TonP on 08-05-2009 01:25 PM
My LabVIEW Ideas
(2,939 Views)
