Overcomplicated Array Operation
I am coming behind another programmer and his code is rather inefficient. This array operation seems way overcomplicated and i was wondering if any Labview Gurus out there could post some code that does the exact same thing, but isn't so obfusticated and hopefully is more efficient.
See attatched picture.
[will work for kudos]
(3,300 Views)
This looks like a "puzzle challenge". Do you have a simple description of what it is supposed to do?
Most likely, the solution is a "one liner" 😄
Can you attach the actual VI and some typical data file?
(3,292 Views)
Maybe the original programmer was trying to find out how many array functions they could fit on the head of a pin. Smiley Very Happy
(3,279 Views)
OK, I'm not going to analyze this diagram from a picture. 😮
  • Obviously, we have a "decimate array" primitive, maybe that's what it is supposed to do (from the file name).
  • Using "array subset" to slice out single columns/rows is inappropriate. This is is better done using "index array".
(3,272 Views)
Accepted by rex1030
 He's pulling out the however many rows into single arrays, and then grouping 0-6 and 7-13 into individual arrays and transposing them.  Another option is
Message Edited by JeffOverton on 11-06-2008 03:40 PM
 Duh!  Here's a more elegant option
Message Edited by JeffOverton on 11-06-2008 03:45 PM
(3,228 Views)
