10-10-2008 11:30 AM
Hello NI Developers!
I have windows application driver created by Jungo WinDriver program for PCI-E board.
Application works fine. I edited and compiled the project as DLL following manuals.
I can successfully read PCI-E board's resources information such as memory bars, it's size, interrupt functions etc.
Next step I need to perform DMA transfer. The application supports these functions and works.
I follow function by function and see if my code works correctly and returns to Labview information - about function successful execution.
First of all is strange that every time I close VI I receive error message:
"LabView.exe has encountered a problem and needs to close. We are sorry for the inconvenience"
fDebug: 0 Offset: 0083002e
Exception Information
Code: 0xc0000005 Flags 0x0
Record 0x0 Address 0x0000000000c3002e
But when I build EXE application from VI - this error do not occur.
Maybe someone can help me or point on string where I did incorrectly manage LabView and C resources?
Sometimes LabView crashes after few seconds after successfull execution of VI.
The code attached below:
Solved! Go to Solution.
10-10-2008 11:43 AM
Hi there
Do you pass a string allocated by LV with sufficient length to the char *msg_ptr parameter of the DLL functions?
10-10-2008 11:58 AM
No.. actually I don't know how to allocate space for it..
If It it a case of problem, I should count every single character in those messages?
Best Regards,
ACiDuser
10-11-2008 03:35 AM
10-11-2008 08:06 AM
thanks for the tips.
Is it possible to dynamically allocate memory for LV array from DLL ?
10-11-2008 10:09 AM
To dynamically allocate memory for LV inside the external code you have to use the CIN memory manager functions (for documentation see attachment), but that's a little bit cumbersome and quite old school. Also you may get in trouble when calling the DLL with applications not written in LV.
I suggest to use 2 DLL functions, or to call the same function twice with different parameters. The first call returns the size of the needed memory (e.g. the number of array elements or the number of characters), then allocate the memory in LV by creating an array or string with the given size and then pass the pointer to the allocated memory to the second function call. There should be no reallocation or resizing of any memory inside the DLL functions, otherwise the application may crash.
If you're handling with rather small memory allocation (e.g. strings smaller than some 100 characters) passing a constant puffer with sufficient size also should do the work, that would make the programming easier. In any case the DLL functions should check the external buffer for sufficient size (e.g. with strlen(char* buffer) or by passing array dimension sizes as additional function parameters) and catch buffersizes that are to small, otherwise the application may crash.
10-13-2008 03:58 AM
10-24-2008 01:57 PM - edited 10-24-2008 01:59 PM
If you create an array in LabVIEW this IS dynamically allocated and disposed as soon as LabVIEW deems it unneccassiry (meaning the wire stops being run through the diagram). Then you configure the apropriate CLN parameter to accept an array or string and configre this to be a C Array Pointer or C String and your DLL will see a simple memory pointer it can use to write its information into.
And after the return from the CLN you have the data back into proper LabVIEW wires to work on them. If you use the CLN to call LabVIEW memory manager functions you really just get a pointer (uInt32) and after returning from the DLL will have to do additional LabVIEW manager calls to actually get the data into the diagram.
Also this DLL will continue to work with other callers than LabVIEW as it uses common C data pointers as memory buffers instead of proprietary LabVIEW data types.
So why making your life more complicated than necessary?
Rolf Kalbermatter
