04-28-2008 10:09 PM
04-28-2008 11:59 PM
Hai Nyan Lin,
Collect all the VI's and C files in the same folder.
Also check whether you have given the correct path to access the files.
Whether you got same error before creating exe?
Mathan
04-29-2008 02:37 AM
Hi Mathan,
Thanks for ur reply.I make double check my VIs and C files also contain in same folder.The problem is that after i debug, the error come out.I can run my tutorial inside the front panel.But when i transfer to PDA emulator,the emulator never come out and the error as in pic is come out.I all follow through is by tutorial sheet that from NI. I am a bit confuse is although the emulator have inside my software, i can't see it.So is there any way to solve my problem? I urgently need to know how to transfer to PDA for my final year project.Now i am doing final year project from Nanyang Polytechnic (Singapore).So I am thanks a lot to give me ur time for me.
Warmly Regards
Nyan Lin
04-29-2008 06:55 AM
Do a search in this forum with the keyword - "labview pda - Window Mobile Emulator 5.0"
You can get a couple of solutions.
Mathan
04-30-2008 02:25 PM
05-01-2008 08:30 PM - edited 05-01-2008 08:35 PM
Hi Eli,
I am using the Getting started with the LabVIEW PDA Module for Windows mobile for version 8.5 which is contain in the labVIEW software.This tutorial you can also find from following link.Thanks for help me and sorry for reply late.
http://www.ni.com/pdf/manuals/371296c.pdf
with Regards
Nyan Lin
05-07-2008 08:56 PM
06-02-2008 01:28 AM
06-03-2008 12:55 PM
