04-25-2008 01:46 PM
04-25-2008 02:11 PM
04-25-2008 03:15 PM
04-25-2008 03:18 PM - edited 04-25-2008 03:19 PM
Not to preach, but some other safety points:
Wear the proper laser safety eyewear rated for the specific wavelength of the laser and with the proper optical density for attenuation to an eye safe level.
Use beam dumps or blocks to stop the beam if the terminal end of the path can be removed.
Post the proper signage to warn others in the area of the laser Class, wavelength, and power level.
Ideally, have a warning light that illuminates when beam is on.
If I get a chance (I'm currently running a battery of tests on a lser based unit right now), I'll try to download the docs for the supply to review (or you can post them), also what model is the laser?
-AK2DM
Edit: I see you posted the manual while I was 'composting' my post
04-25-2008 03:21 PM
04-25-2008 03:28 PM
04-25-2008 03:35 PM
Karl:
Section A-1 in the manual covers start up process for computer control.
Also- does the laser function properly under manual control?
Sorry for the barrage, but I gotta run now. Good luck and be safe!
-AK2DM
06-26-2008 12:50 PM
