Error 1047 w/ Labview 8.20: Labview failed to send variable to the script server
I have found similar questions, but with previous versions of Labview and Matlab and no resolution. Could someone please enlighten me? I'm using Matlab 7.4.0 (2007a) and Labview 8.2 and this is the error I get when I try to input a 1D array into a matlab script node.
Thank you much.
Message Edited by johng3 on 02-11-2008 01:20 PM
(3,927 Views)
Okay, I was able to fix error 1047, but now I'm getting error 1048: LabVIEW failed to get variable from the script server.
Many posts mention example .vi's, but the example .vi's by the same name in LV 8.2 (i.e. Lorentz Diff Eq. vi) us Mathscript instead of a Matlab script node, so trouble shooting with them does not seem to be an option.
I know that my variable names are okay.
Any help would be great.
(3,916 Views)
Hello Johng3,
Regarding error 1048 you are getting, please refer to this knowledgebase, which explains why this happens.
Eli S.
Applications Engineer
(3,901 Views)
