run a for loop for specified time period
Hi
I want to execute a for loop for a certain specified duration which keeps changing.I want to specify the duration for each run and I want a for loop to be excuted for the same.So how do I  interface a timer to the for loop's loop count?
Sukanya
Message 1 of 8
(8,261 Views)
Do you want to run the loop for a variable amount of time or for a variable number of iterations?
Message 2 of 8
(8,258 Views)
I'm not too sure.This is what I need.I have a VI that captures videos and saves it as a .avi file.Now I need to add another label to the display through which I can specify how long ( in seconds) the video should be captured.I initially had the VI writen using a while loop.I changed it to a for loop so that I can add this parameter.But I'm kind of confused now as to how to proceed.
Sukanya
Message 3 of 8
(8,246 Views)
Sounds like you would want to run a Loop( at a preset iteration rate) for specified number of seconds. Is that correct?
Message 4 of 8
(8,225 Views)
you can use Timed loop for the said purpose it will work fine as i think
Haider
Message 5 of 8
(8,213 Views)
Yes,that's precisely what I want to do.
Message 6 of 8
(8,204 Views)
Look at attached VI
This link will teach you how to configure a timed while loop
Hope this helps
Dev
Message 7 of 8
(8,201 Views)
Oops, my example was a wrong one, please remove this reply.
Message Edited by Eugen Graf on 01-16-2008 08:08 AM
Message 8 of 8
(8,200 Views)
