10-30-2007 01:10 AM
10-30-2007
01:19 AM
- last edited on
07-08-2024
11:50 AM
by
Content Cleaner
Did you also install the scilab gateway files in the 8.5 program folder after installing LabVIEW 8.5?
10-30-2007 05:10 AM
10-30-2007 06:31 AM
10-30-2007 10:50 AM - edited 10-30-2007 10:50 AM
Yes, the examples work fine, with one ugly difference:
In LabVIEW 8.5 the code (e.g. "Scilab Life" example) no longer wraps to multiple lines.
(I am not sure why the example code is formatted as a single line and not structured normally)
Message Edited by altenbach on 10-30-2007 08:51 AM
10-30-2007 11:49 AM
altenbach,
The single, unreadable line of code in each example is my fault. I created the examples for a pre-alpha version of the Gateway that didn't support carriage returns, then I forgot to update them for the fully functional version. I'll see if we can update the examples on the download page. The difference you see between 8.2.1 and 8.5 won't be so ugly once carriage returns are inserted.
Chris
LabVIEW R&D
10-30-2007 12:06 PM - edited 10-30-2007 12:06 PM
Message Edited by altenbach on 10-30-2007 10:07 AM
10-31-2007 02:40 AM
10-31-2007 03:00 AM - edited 10-31-2007 03:00 AM
@Andreas wrote:
i guess, i find one point: In the block diagram window in LabView
8.2.1 i make a right click on the script-box and open the menu item
"choose script server". Here, Scilab is displayed and choosen.
When i do the same in LabView 8.5, the menu item "choose Script
server" does not show me Scilab. The entry "Scilab" is not available.
Works just fine here in LabVIEW 8.5. Did you restart LabVIEW after installation?
Message Edited by altenbach on 10-31-2007 01:00 AM
10-31-2007 09:58 AM
