09-28-2007 03:03 PM
09-28-2007 03:38 PM
I have not ran your code yet but I do have a couple of suggestions that may help.
09-28-2007 03:47 PM
I agree about the wiring. The formatting that is done with the concantanate string function is just too messy to understand.
A point about the Read From Spreadsheet File. In 8.0, the function was only capable of outputting numbers. This all changed in 8.2 but the diagram for the Write to Spreadsheet has instructions on how you can modify the VI to output strings. I would suggest you do that as well.
And you are correct about the sequence structure. It should be eliminated.
09-28-2007 04:03 PM
09-28-2007 04:04 PM
09-28-2007 04:04 PM - edited 09-28-2007 04:04 PM
Message Edited by Ravens Fan on 09-28-2007 05:05 PM
09-28-2007 04:46 PM
09-28-2007 04:48 PM
09-28-2007 05:06 PM
09-28-2007 05:10 PM
