09-19-2007 08:59 AM
09-19-2007 11:07 AM
Hey Mads,
On both XP and Vista, I successfully used the Palette Editor to place the Serial Port Init.vi on an existing LabVIEW palette. The VI did not disappear after exiting the Palette Editor and when I relaunched the Palette Editor, the path to the VI was not incorrectly listed as being under my documents directory hierarchy but rather under Program Files in LabVIEW's vi.lib directory.
So, we need to figure out where we are differring in our steps to reproduce the problem. Below are a few questions to help figure this out.
a) Which LabVIEW palette are you attempting to put the Serial Port Init.vi? I put it on the Programming palette.
b) If you modify a LabVIEW palette, the editor saves a mirror file of the modified palette into your Documents directory hierarchy. E.g., <user documents>/LabVIEW Data/8.5/Palettes/menus/categories/programming/dir.mnu. Was such a palette menu file created on your system? If so, can you post this file? If not, was any file saved into the Palettes directory under your documents directory hierarchy?
c) Have you disabled UAC on Vista? Did you launch LV as a standard user or administrator?
Thanks a billion,
Noel Adorno
09-25-2007 08:32 AM
09-26-2007 01:42 PM
10-15-2007 04:34 AM
