02-12-2007 04:30 PM
02-12-2007 06:12 PM
A VI should never be associated to any runtime engine. Something is wrong.
Have you tried to repair the 8.20 installation or e.g. reinstall the 8.20 runtime engine?
02-13-2007 08:01 AM
02-13-2007 01:48 PM
02-13-2007 05:01 PM
Hi romulus,
I'm a little confused by your question. What do you mean by the following:
"all the VI icons in the folder take the appearance of 7.1 icons "
When you run an EXE, you shouldn't see any icons or folders. Your application should start running immediately. Are you sure that you're running the .exe file and not just double clicking on one of your VIs or an llb? Something that you could try is while you have your LabVIEW 8.2 project open, right click on your build specification and select "Run". This will run the exe that you just made.
Justin D
02-14-2007 08:44 AM
02-14-2007 01:32 PM
