12-01-2006 09:12 AM - edited 12-01-2006 09:12 AM
Message Edited by Midlothian on 12-01-2006 09:15 AM
Message Edited by Midlothian on 12-01-2006 09:24 AM
12-06-2006 04:53 AM
12-07-2006 04:14 AM - edited 12-07-2006 04:14 AM
Hi James,
Here is a SV example with the spectogram like I was using. Could you explain how to get Z in log mode please?
The" Colormap" is an intensity graph and replacing it with a new intensity graph still does not enably Mapping, Logarithmic to be selected - (it is present, but not in black type).
Message Edited by Midlothian on 12-07-2006 04:23 AM
12-07-2006 04:42 AM - edited 12-07-2006 04:42 AM
Message Edited by GerdW on 12-07-2006 11:43 AM
12-07-2006 04:27 PM
Gerd
The option mapping for is disabled as I pointed out.
The thread did not show on a search so I created a new one. Then searching on other keywords showed the other post still unanswered.
Since this is a support forum and since I pay for this support it seems reasonable to post as I have done.
12-18-2006 03:31 AM - edited 12-18-2006 03:31 AM
Message Edited by JamesC on 12-18-2006 09:32 AM
12-18-2006 06:00 AM
12-19-2006 08:51 AM
12-19-2006 09:34 AM
Hi JamesC
Thank you for your advice. I have added the suggestion as shown below.
Spectogram Support for Logarithm Frequency Scale
The Intensity Chart or Color-map currently does not support the
logarithm map mode to enable the spectogram to plot in the normal
standard for the Noise & Vibration analyst.
This results in the requirement to take recordings and then use third
party software to produce compliant reports. The inclusion of a
logarithm scale would enable realtime use of the LabVIEW spectogram.
