Why does not work my LabVIEW VI on PDA well? -without error message
I have a LabVIEW VI with subVI's. It works on desktop Windows very well. If I buid it for PDA , there is no error messages. When i it start on PDA, the problem seems to be on the chart.There is an Adams-Basforth Integrator subVI, and in the subVI there is a Formula Node, perhaps there is the problem. I use LabVIEW 7.1 and PDA Modul.
How can i build this LabVIEW VI for PDA perfect?
(3,158 Views)
Dear smarci
Have you tried building your VI without the SubVIs ("CLK.VI", "INT.VI" and "TIME.VI"). It would be interesting to see whether these cause the program to not execute properly.
Have you looked if your PDA's resources (i.e. RAM memory) are sufficient for you VI?
Best regards
Philipp Roessler
(3,129 Views)
