11-02-2006 08:53 AM
11-02-2006 09:23 AM
oceaneyes-
I have never used MAX to view a video feed BUT I would not rule out the camera/optics just yet.
Ideally you should use a scope with a trinocular port that is specifically for camera use. Different manufacturers of scopes have different length optical paths between the main objective and the eyepieces. The eyepieces have a specific focal lenght to focus the virtual image from the main objective and magnify it to present it to your eye. If the camera and its lens have a different mag or focal length, the field of view and mag of what the camera images will be different from what your eye sees.
What type of camera is it? If it is analog NTSC or PAL you are in luck- just plug the analog signal into a TV monitor to really see what the camera is imaging- this will confirm if MAX is indeed the culprit.
11-03-2006 11:26 AM
11-20-2006 02:04 PM
I have attached a picture of the object's image being displayed on the pc monitor. Where the field of view (FOV) in the microscope is almost 30 mm, the FOV displayed onscreen is about 7 mm. After contacting companies various times I discovered there was a reducing lens that goes in the C-mount adaptor, but it is over $300.
I thought maybe that the FOV could be changed in in NI Measurement and Automation Exploer (NI-MAX). Any ideas?
11-20-2006 02:19 PM
11-20-2006 02:22 PM
I do not think MAX will be able to expand the FOV beyond what the camera itself sees.
Can you plug your camera into a TV monitor as a sanity check to see what the true FOV is?
11-20-2006 02:59 PM
From this other post, I see it is a 1394 camera, thus disregard my suggestion of trying to plug it into a TV monitor![]()
http://forums.ni.com/ni/board/message?board.id=200&message.id=11842
11-21-2006 02:01 PM
11-22-2006 02:33 PM
02-07-2007 09:34 AM
