08-25-2006 01:56 AM
08-27-2006 10:46 PM
08-28-2006 04:47 AM
Hi Paul,
I have access to 8.20 but not for RT or DSC. My customer Wyle Labs will be contacting NI since they have SSP and should have received the new CDs but still haven't.
Another thing that happened is that the test app that has a control that writes to a SV and an indicator that is bound to the SV now only runs about 50% of the time without crashing the SVE.
I upgraded everything (LV, DSC and RT) from 7.1 to 8.0 to 8.0.1. Is there a possibility that I have an old DLL or library? I would hate to have to rebuild the machine from scratch (XP SP2 + LV) but will if there are any known problems in upgrading liking I have.
Thanks.
Randy
08-30-2006 11:40 PM
09-01-2006 06:42 PM
I was able to get LV 8.2 including DSC and RT installed and it seems to have fixed the problem. I was able to successfully launch applications around 20 times with no failures.
I noticed when installing RT SW that the SVE went from 1.0 to 1.2, I don't know if there was a version 1.1.
Also, I did a clean install of LV 8.0.1 on another machine (w/o DSC) and had no problems with the SVE but since I wanted logging to Citadel plus historical and security I need DSC. Have not added DSC to this install but upgraded to 8.2. I should have put in DSC but didn't think about it until after I installed 8.2 (goofy me).
Thanks for your help.
09-01-2006 07:25 PM
09-01-2006 07:30 PM
Hi Paul,
I have 7.1, 8.0 and 8.2 on all machines except the one where I was trying to see what it would take to fix the SVE. I also have 5.1 loaded on one of the machines.
Thanks.
Randy
