06-25-2006 05:11 AM
06-26-2006 01:56 PM
06-27-2006 04:04 AM
Thank you for your answer and part of code. But it is not the case I am interested in. I would like to change the cursor panel appearance and content programmatically for example the number of rows displayed, the number formatting type and precision, the number and size of columns and so on. I suppose that some of it is not possible even in design mode. I am afraid I have lost these possibilities after upgrading to LV8.
Zygmunt
06-28-2006 02:09 PM - edited 06-28-2006 02:09 PM
Message Edited by JLS on 06-28-200602:13 PM
Message Edited by JLS on 06-28-2006 02:24 PM
06-29-2006 01:27 AM
Thank you JLS once again.
In my opinion the cursor palette at list should have the following functionality:
Having additional elements (coming from underlying tree control) is not necessary in several cases. Life will be much more pleasant if it will be possible to get reference to this tree control.
By the way it is possible to customize this palette. In design mode configure WaveformGraf to show cursor legend. Select it and then select from menu “Customize control…” Now you can do whatever you (I) want, for example change the column name from X to Time. Save your work, if prompted replace original with just designed and… nothing changes – funny isn’t it?
Zygmunt
06-30-2006 01:46 PM
