03-20-2006 07:08 AM
03-20-2006 07:20 AM
Hi aaa,
Do you have a model of the water flow (ie: pipe size, pressure & other parameters) that you want to simulate?
If so, then you can start building that model and create some controls so that you can "externally" modify the parameters while the model is running. So start with the model.
Can you describe what you tried to do when customizing the numeric controls? >> "I tried to costimized the numeric control but found the effect didn`t reach my anticipation. what can i do? <<
Also, can you describe the end goal, it may help to better understand what you want to achieve.
JLV
03-20-2006 07:59 AM
The easiest way to do this is shown in the attached VI (7.0).
The trick can be understood when the cluster is enlarged - a customized slide was used where the image of the slider was replaced with the image of the flowing water (created very quickly in Word). Moving the image repeatedly creates the appearance of continuous flow. The credit for this trick, as far as I'm concerned, goes to JPD.
This can also be done using the picture control or maybe an intensity graph, but that would probably be more complicated.
03-20-2006 10:47 AM
Very nice tst, and very nice trick indeed 🙂
Was this what aaa was looking for?
03-20-2006 12:58 PM
03-21-2006 03:07 AM
03-21-2006 03:41 AM
03-21-2006 06:17 AM
03-21-2006 08:29 AM - edited 03-21-2006 08:29 AM
Good suggestion dev!
-- forgot my signature smiley --
Message Edited by JoeLabView on 03-21-2006 09:29 AM
03-21-2006 08:36 AM
