02-06-2006 02:04 PM
02-07-2006 01:45 AM
Is this property supported in 8.0 PDA?
I haven't had a chance to see 8.0 PDA yet, so I don't know how it works with unsupported properties - does it break your VI? Does it alert you at build time? Does it simply remove the unsupported ones from the selection list?
Is flipping the scale the only thing you are doing in your example?
02-07-2006 11:56 AM
02-07-2006 01:42 PM
And is this the only thing in the example? I have seen cases in the past where seemingly unrelated code caused such errors. If it is the only thing, then this is probably a bug, at least in the sense that the node should break the VI. You will need someone else with 8.0 to check that. Are other scale properties supported?
BTW, they haven't been "attribute" node for several versions already. ![]()
02-07-2006 02:00 PM
02-07-2006 05:02 PM
Thank you all for helping with this.  I have reported
this issue to R&D to investigate (CAR #3U6F043A).  I suspect that this
is just one of the properties that is not supported on the PDA, so you might
want to consider an alternative.  If you had any questions on this please
let us know!
Thanks for posting, and have a great day!
02-07-2006 05:55 PM
08-17-2006 11:25 AM
@Travis M. wrote:
Thank you all for helping with this. I have reported this issue to R&D to investigate (CAR #3U6F043A). I suspect that this is just one of the properties that is not supported on the PDA, so you might want to consider an alternative. If you had any questions on this please let us know!
This was reported to R&D (# 3U6FO43A), but was determined to be expected behavior because the only slider scale properties that are supported on the PDA are scale.visible, scale.range.maximum, scale.range.minimum and scale.range.increment.
As for the documentation on this property... This was reported to R&D (# 3WDICL00).
Thanks for the feedback!
		09-28-2006
		04:44 PM
 - last edited on
		07-13-2025
		12:56 PM
 by
			Content Cleaner
For the documentation "bug"...
This was reported to R&D (# 3WDICL00) and was fixed in LabVIEW 8.2 PDA. Here is a link to the current evaluation software download for LabVIEW.
Thanks!
