12-01-2005 10:48 AM
12-02-2005 05:23 PM - edited 12-02-2005 05:23 PM
Message Edited by Andy F. on 12-02-2005 05:23 PM
12-09-2005 10:02 AM
12-10-2005 05:01 AM
Hey Andy,
Thats the nice solution and i am also finding the problrm that Raj is facing, isnt it possible that you can attach the vi you have creatd, so that we can analyse it by run it, it is more understandable for me other then anybody.
Hope for the positive reply.
Nishant
12-11-2005 05:44 AM
12-11-2005 06:03 AM
Andy,
Some of the things i tried for my implementation was..
i used "LOGIN" as the string for the IHTMLElementCollection for ""name"
but when i debugged with the help of probe the output of IHTMLElementCollection showed me value->0.
then i got an error..
the "LOGIN" string which i used was from the HTML code of the web page.It was given in the HTML page
<FORM name=LOGIN action="login.htm" method="post">
<input type="hidden" name="page" value="login">
<input type="hidden" name="GetTimeVal">
<td width=30> </td>
so i used the form name as the string.
But for the other two (IHTML Form element and IHTML element ) I dont know what do pass as string values form the
HTML code.
Please correct me if i am wrong
regards
vevek
12-11-2005 09:20 AM
12-12-2005 07:46 AM
thanks ravis..
but the problem is i have a html pages in frames ..i mean there are 3 frames are put into a html page!!! unlike google.com where there is only 1 html page.
when i call the url what i get is the main frame and under that there are 3 frames ...
i need one of the 3 frames and search for a form and submit the form!!!
Andy, is it possible to select a particular frame in html page and search a form in that frame and submit it.
i have attached all the html files of my application in zip format!!
regards
vevek
12-12-2005 10:45 AM
Hi Andy,
You could see lots of mails in the forum reg this auto login issues.
I have said in my previous post that i have 3 frames of which i need one of the frame and in that frame i have the form where i should login..in labview we have
functions in ActiveX which can take frames from html page..but how to use those functions ..i mean the IHTML properties!!
could you please suggest me a way of doing the following in an automated way ..
1. login to a html page
2, get the frame which has the form for login(depending on the frame name. We would know it from the html code)
3. fill the form and press submit button
regards
Vevek
12-12-2005 04:42 PM
